@Trailynn, you mentioned battery life so I assume you're looking at handheld radios, yes? Here are two solid options to consider:
- The Baofeng UV-9G is a full-featured, very economical GMRS radio that has a removable battery (so you can own more than one) and a removable antenna (so you can add a roof-mounted antenna for better range while you're on-trail).
- The Midland GXT67 is highly regarded, although a little more expensive. Unfortunately neither the antenna nor battery are removable, but it can be charged (from 115Vac or 12Vdc) while in use.
If you're looking for a mobile unit to install in your vehicle, Midland's MTX275 and MTX575 are both excellent GMRS radios and I second (third) the advice that having controls on the mic' is useful and allows for a clean installation. If you're exclusively using this radio to communicate with your friends on-trail, then the economical MTX275's 15 watts of power will be sufficient (assuming a properly installed antenna).
@Trailynn I know that your question is specifically about GMRS... but at the risk of derailing this topic, here is my 2¢:
IMO a lot of first time radio buyers are selling themselves short by choosing a GMRS (or worse a "race radio") instead of going with a
ham radio right from the get-go. Ham radios offer many benefits; most importantly they can be used with a nation-wide network of repeaters that allow them to communicate over hundreds of square miles (in some cases much more!). They also generally have greater range in simplex mode (person to person), and some models of ham radios can be modified to transmit/receive outside of the typical 2M/70cm bands**, this means that a single radio can be programmed with ham
and GMRS frequencies (
plus race radio freq's). The downside of starting with ham is that you need to take an in-person test and receive a license in order to transmit, rather than just applying for a GMRS license online. Also ham's can be more expensive than GMRS radios, but there plenty of economical ones too.
73! ("best regards" in ham-speak)
-Mark
** Note that there are real legal implications with regard to transmitting outside of a frequency band that a radio & operator are licensed to operate in. However a lengthy discussion about that would be outside the subject of this post
