The wife & I offroad squaredrop camper
Maranatha Adventures
Weekend Warrior
Somewhere in the Ozarks
I bought this 2019 Runway Range Runner new over 5 years ago (last year of plywood construction)new in Florida from Runway Campers, it was their street version called the Range Runner with a 6ft. x 8ft. cabin (1st picture shows it in original). I put over $9,000.00 & a ton modification's for offroad capabilities. Done all the work myself & no corners were cut, only quality was done.
Work done: I removed the original A Frame style 2" tongue & fabricated a new & longer 2 1\2" tube tongue w\ 2 1\2" partial backbone & 2" hitch receiver on the front of the tongue. Hitch & Coupler is Lock & Roll Hitch (adjustable in height) that slides into 2” receiver hitch on the fabricated tongue, suspension work Dexter Axle Flip Kit & shocks, I fabricated the shock mounts sitting on the original 3500lb Dexter Axle. The trailer has 24 1\2" of chassis ground clearance, 14 1\2 " of axle ground clearance. Matteress is a queen short that is 7” thick (4” foam with 3”memory foam topper). 5000 btu air conditioner runs on 110 shoreline power or generator inverter. 55amp Powermax Converter AC to DC \ Charger (built-in 3 stage charging and fixed single output modes), heavy duty roof rack. Two 30"x 20" tinted safety sliding glass \windows w/screens (left side & right side), two 22"x 42" RV locking entry doors w/windows, 40" x 40" rear door locking (storage area) all doors keyed the same including dead bolt, waterproof membrane underneath the entire bottom of the coach.
I done all the electrical wiring (over sized by 2 sizes in gauge) set up for 12v & shoreline 110, battery is VMAX 125 ah AGM, solar is all Renogy with 100 watt folding suit case style with hardcase, I done all the interior work, rear storage (which is framed in 1 1\2" aluminum welded) sandwich over in 3\4"birch cabinet grade plywood finished off in navigation compass wallpaper in the sleeping area, storage side holds all the camping gear, explores trunk Condition One 44.52" x 16.30" x 12.90" mounted on roof rack, swing out spare tire carrier left hand swing, C Series 5000lb rear stabilizer jacks, tires are 235 x 70R x 15's General Grabbers AT2 including spare & rims are the originals to the Range Runner but had them powder coated to satin black including the spare, done all the diamond plate on the sides & coated them with 2 part truck bedliner on the tongue, front of the coach (rock guard) & side pieces lower half of the tongue box & front’s of the fenders all sprayed 1\8” thick, white paint work on fenders (all automotive), tongue box (PPG Automotive Paint: epoxy primer, base white & 3 coats clear coat). It has thermostatic controlled forced air heating Proplex H2000 that is portable the kit I bought from AT Overland that pulls only 1.4 amps hour & uses 5lbs propane in 72 hours, two 5 gallon AT Overland Scepter Water Can Mounts sprayed in bedliner w\locks keyed the same, Rhino Rack Batwing 270 Awning (right side with zippered walls), Rugged Ridge hi lift jack mount keyed the same as the Scepter can mounts, 1 Roto Pac 2 gallon Fuel Pac with keyed mount, 1 Roto Pac 2 gal Fresh Water Pac with keyed mount, Trashroo mounted on spare tire, six 12v. socket outlets: 3 mounted on tongue box, 2 mounted in the sleeping quarters, 1 on the left side behind the tire, three LED exterior lights: two 12v left side & right side, one 12v LED exterior light @ the rear. LED tail lights. Darche shower ensuite mounted on Kimberley2Cape swing out shower ensuite mount.
57400156_2171913132857549_8052162905098944512_n.jpg 452209980_499133915992630_8296089238658863823_n.jpg 451872823_7801829259865880_8040836990480868036_n.jpg 440361479_455924980313524_1797447461331134781_n.jpg 412742355_6896053770443438_8081442694644974907_n.jpg 363829769_6369217786460375_5262578173849994645_n.jpg 438685135_7378364425545701_4112216348454995028_n.jpg
